Just doing tests on my thermostat in the cruiser (180 degree thermostat) I have found that it is completely closed until approx. 185 degrees or so and then slowly opens. It only allows a little bit of water through at that point. By the time the water gets to about 200, it has opened almost all the way and is totally open at 212 degrees-boiling point. Though obviously, the coolant doesn't boil at 212 in the car because of the 12-14 pounds of pressure. According to all my textbooks, the thermostat should open at the temperature specified, but can vary by about 5 degrees without considered being defective. At the specified opening temperature, the thermostat will only be slightly open. At boiling point the thermostat should have at least 1/4" of opening.
