Radiator reservoir not emptying (2 Viewers)
First of all, thank you for everyone’s help.
I’ve replaced the fan assembly, water pump and radiator and have filled the reservoir. I’ve burped the hoses and followed the FSM, but I don’t believe the coolant is circulating. The temp gauge creeps up to 3/4 at 2500 rpm at which point I shut it down.
What say you?
Park on slight incline. Fill radiator to top. Start engine without radiator cap on. Squeeze upper radiator hose to distribute. It’s a self bleeding system. Sound likes it’s low on fluid.
Thank you, sir!
@04UZJ100 is spot on.
If you were looking for a more foolproof, faster, and thorough method, this can help
EPAuto Spill Proof Radiator Coolant Filling Funnel Kit https://a.co/d/bxGzAIM
I speak from experience here: if the rig is parked nose-down even that tool won’t be sufficient. Otherwise yes it is great.
It doesn’t take much incline, but it sure does seem to help to have at least some.
Agreed. Nose up is preferred, but level is fine with this tool. Even level with this tool, it will burp much faster and thoroughly compared to no tool and nose up. With minimal to no topping off in the drive cycles after.
Thanks everyone for the assist. I’ll report back. May have to order the EPAuto Spill Proof Radiator Coolant Filling Funnel Kit. I didn’t realize Playskool made automotive tools.
Have done several coolant jobs on my Toyota trucks without issue - all raw-dogged with no spiffy plastics.
poke fun if you want, but if you want to properly burp the cooling system, by the kit.
also, you’ll probably never see it pull coolant from the reservoir
The kit is a ‘nice to have’, not a need to have by any means…..you can do it properly, and very easily, without.
I also have that funnel kit, it makes things so much easier and less messy. Total spillage is about a tablespoon, which is an easy cleanup. Highly recommended.
In complete agreement with you. I can do it without and you obviously can to. The kit just takes some of the guess work out of it for the average person. I don’t know everyone’s skill level. That large funnel lets you see the air escaping easily. You can see when your thermostat opens easily and know your water pump is circulating properly. All for $19.99. Well worth it imo.
Sorry, wasn’t disparaging the product, just making light of the colors chosen.
