jfz80
Cruisin’
So im workin on hour 3 of the radiator flush and here is my delima. I drained the radiator and block, installed flush 'T' ran and flushed block/rad heat on and off. Now when i tried to fill i got the one gallon toyo red in and then only about 1/2 to 3/4 gal. of water in for a total of 1.5 gallons. it should have over a gallon of fluid left to go. I tried running the vehicle for over ten minutes and cannot get any heat through the vents nor can i get the level of fluid to drop in the radiator. it did push the 50/50 mix out the overflow. What do you guys think? air in the system? stuck t'stat? ( it was replaced less than 18 mos ago )
temp is normal(just below 1/2) only thing odd is rich smelling exhaust.
