Definitely give CruiserDan a call or message, you wont find a better price or better service anywhere that I know of.
Ask about the three row brass rad as it is less expensive than the two row aluminum rad.
Whatever you do, dont make the mistake I made on my 4Runner and get another brand of rad. At that time I compared prices and found that the "lifetime warranty" rad from McParts was about two hundred dollars less than what my local stealership wanted. (That was way before knowing about CruiserDan)
Anyway, I got the off brand rad, put it in, and found out the fawkin thing was slightly taller and slightly wider than the factory rad! The wide part was easy to work around it just required slotting out the brackets that wing off the side of the rad. The tall part was also easy to work around once I gulped and realized the way to 'fix' the fawkin thing was to purposely dent in the support structure of the hood right above the rad cap! It only took one small half dollar sized dent in the support rail to give the thing clearance but these are the sorts of things you always end up doing by dicking around with off-brands from mcparts places.
Ohh, the really good part, ... I used the "lifetime warranty" feature three times over the course of three years til I found a rad that luckily did not leak!!! So here's the question: How do you go about turning an inexpensive rad into a more than stealershiply expensive rad? Answer: Pull it and replace it three times at three hours each and then multiply that by your hourly rate!!!
HTH
Let's all sing to snoop's ballad:
Snoop: "Who's the man with the plan?"
Chorus: "CruiserDan!!!"
Snoop: Bowwowwowyippeeyowippeeyaaaa, feed dem dogs every single daaaayyyy!
Bass line kicks in, toes start tappin!!! Watch out now cause TurboCruiser is rappin!!!
Sorry, way too little sleep last night!!!
