TX_TLC said:You can do it yourself with the bottles of R12 from Walmart, Autozone or almost any other auto parts store. They even have the leak detector stuff so you can pin point where your system is leaking. HTH
rick_d said:I am no fan of 134a in this heat.
rick
tucson, az
-Spike- said:R-134 only has issues in cars with small condensers. I don't have specific information, but the LC shouldn't suffer in that area.
-Spike
LandCruiserPhil said:R12 all the way in AZ -
I have 2 cruiser that run on R12 and provide the coldest AC of all my junk. I will run R12 for ever until it is no longer available or untill the 33lbs of R12 in my garage runs out.
-Spike- said:Very slight, and sometimes none.
And certification for R-12 involves taking a written test.
-Spike
Kalawang said:R-12 aircons need large modifications to use 134-A. 134-A has much smaller molecules than R-12 and if you fill your R-12 system with 134-A you will experience success for at most a month after which it will have leaked out enough to be ineffective. That was my experience when I tried to change from R-12 to 134-A simply by draining out the R-12 and pumping in the 134-A. 134-A's smaller molecules find leaks which don't exist for R-12 and the best way to convert is to change your system including compressor and fittings ( Effectively the whole air con ). I had to return to R-12 as I didn't want to spend for a new air con.
Kalawang
Koffer said:Shhhh
Dont tell this to my 92 as its been running R134a in it for over 5 years and 50k I havent had to top it off yet
Kalawang
Kalawang said:R-12 aircons need large modifications to use 134-A. Kalawang
-Spike- said:Sorry you had a bad experience, but I stand by my earlier statement. Most systems will run satisfactorily after being converted to R-134 with very little equipment change. I believe the system should be flushed to clean out the r-12 compatible oil. The dryer should be changed, and changing the expansion valve will give better results. I have heard of a variable expansion valve that will adjust to changing pressure resulting from engine RPM changes, and it's supposed to work with both refrigerants (or they have them for both, I disremember) giving improved performance at idle and high RPM.
I'm no A/C expert, so if someone is thinking of going this route I encourage you to search Google for more information.
-Spike
