3 tons no oroblemJust ran across this thread. I bought a Quick Jack about 2 years ago for my Audi S6 to do wheel swaps and oil changes. I did the measurements based on directions from the Quick Jack web site and decided to go with the 7000EXT knowing that I would eventually get an SUV or truck again. I wanted the larger model that could support the extra weight and some assurance with the EXT on length. Fast forward, I just picked up a 2018 LC and wanted to do some PM on the KDSS valve and spray the underbody with Fluid Film in preparation for winter and salted roads. I bit the bullet and went with the truck extensions to get a bit more extra lift height. Ordered extensions from Home Depot. Used today and they worked great. Put the tarp down so Fluid Film spray didn't get all over the driveway using my air compressor. In all, it was a smooth process.
Agreed, makes tire rotations and driveshaft lubes so much easier. Yes the original wheels are junk, surprised mine haven't busted yet.Just used mine again yesterday to swap to the summer tires and lube the driveshafts. Still lovin' the thing. Convinced my brother to buy one, then he bought one for his son for a Christmas present.
OH, BTW, the little wheels on the ends are junk, mine fell apart. I found these on Amazon, much better:
Amazon product ASIN B07H9ZG825
I had to do a little bit of clearance filing to get them to work, but it was very minor. Much better when moving the rails around.
I ended up with 40mm x 18mm. I originally tried 45mm diameter, but they were too big, had to return and get 40mm. Still had to do some minor clearanceing with a coarse round file a die grinder.Agreed, makes tire rotations and driveshaft lubes so much easier. Yes the original wheels are junk, surprised mine haven't busted yet.
What size replacement wheels did you get that fit?
(1) jack up the cars especially European cars with adapters is a bit difficult to position right. It usually took more than 15min just to put up the cars.
