Question for Coilover and Air Shock Users. What size Nitrogen Tank should I get? (2 Viewers)
Marana, AZ
I'm linking my truck and I'll need to charge my shocks. I'm not going to be taking my truck to some shop to do it.
What size tank would be recommended for me to have available in my own garage?
I was getting my welding tank swapped out today and they want ridiculous money to buy a tank and over a buck a day to rent. The guy at the counter said to buy online or find used with current cert.
I have the equipment to do it. I used to be a field mechanic for a Caterpillar dealer and charged nitrogen accumulators quite often. We had industrial sized bottles. I don't think I need that. I never had coilovers so I don't know how often they need a charge or even how much they typically use.
I will keep it in my garage and maybe in my tow vehicle on out of state trips. So what size tank?
5-10 lb should do it. Once charged you do not need to do it often unless you have a leak. Not sure what cu size those are.
Thanks for the reply. I'll have to see if I can find what that is in cubic feet.
I had one person say 80 CF would be more than enough. I've seen 60's and 40's available at my supplier as well.
You'll be fine with a 20CF tank.
Definitely heading towards the less expensive side if 20 will be enough.
Even if you need to refill it once, its much smaller and easier to store, handle, etc. These cylinders are high pressure and you're shocks should only take 150psi, so you should have more than enough volume and pressure to charge them.
I’m off to exchange my argon tank for a nitrogen tank. Thanks for the tips, Evan.
PowerTank has some nice set ups
I have the fitting from powertank. Airgas gave me a 60 sf tank exchange for $30! Maybe that’s expensive but I was expecting to pay more.
If it gets the job done it’s not expensive! Sounds better than messing with a shop for something so simple.
Are y’all’s fitting not just valve stems? That what is on my Fox coilovers.
Got any buddies who are still field mechanics?
As was mentioned it should be a one and done deal, so you don’t have to own a tank if you don’t want to.
@Ditcherman, unfortunately no more connections to the Cat dealership or the mines. It's been 20 years since I left. I put together a pretty nice charging kit so I'm good to go.
I use a zero loss chuck.
Mine are all Schrader valves just like Fox and I also have a zero loss chuck as @aztoyman mentioned.
