- Joined
- Jan 11, 2014
- Threads
- 26
- Messages
- 579
- Location
- North Georgia
- Website
- marcstpierrephotography.com
The question has been running in & out of my mind for a good long while. Perhaps I'd asked here before, but I can't remember.
My '79 FJ40 will be built, at a perfectionist level of detail (true to my nature), to become that of an endlessly rugged trail vehicle (directly through brush and along no-longer-kept-up former vehicle paths - within the wide area of the Eastern United States mountainous forests, etc - as they stumble along my path of future life.
Hence, I can not monetarily afford the rebuild to become simply that of "a luxury item" that may more likely than not be sold sometime soon after rebuild. But I do foresee the vehicle becoming worthy enough that I perhaps attend a local Caffeine & Octane type gathering that next Sunday morning, to sport-off the creation & its caked-on mud.
Why not ... apply tinted polyurethane bedliner product, in a smooth as possible way, on strategic portions of the outside of the tub ? As if : under the doors on the rocker panel; or perhaps, to the rear of the doors to above the wheel well and stopping at the topside of tub, which would then extend around to the backside door opening; or perhaps even, the topside of front fenders; and maybe, on the central portion of the engine hood ?
... I speak of the exact same hue of color as rest of vehicle.
I'm NOT saying I'm driven to do this. Not at all !!
So to me, the external, tinted bedliner is an not only a curious question, it's actually a super-important one, as it'd be an even further deviation from the heritage norm, and from that of the non-OEM paint I'd truthfully like to utilize : DuPont's industrial grade Imron Elite single stage of 34031 "Gray Black," which was previously known as "Army Aircraft Green" - which, similarly like the tinted bedliner I speak of, is simply a form of polyurethane.
I primarily speak of tinted Line-X, Monstaliner, or Raptor, whichever, to that of the same as the rest of the vehicle. Many of us here have done precisely that on the inside of the tub; or, both the inside & underside of the tub. ... but why not patches on the outside too ? ... I mean, historically, several of us here literally pasted diamond plate at such strategic places on the outside. ... And speaking of NOT actually protecting the sheet metal, an external layer of diamond plate *surely* must have done just that (instead rotting the sheet metal it's meant to protect)... No ?
There's always the philosophy of, "the heritage of the vehicle will be lost." Or perhaps, "It just won't look right." Or perhaps further, "The bedlner will trap water & the sheet metal will rust, and you won't know it." Or maybe, "If you ever need to repair the sheet metal, and you've got bedliner all over it, you'll have a hell of a time." ... I'll buy these. But will not the ceramic within the polyurethane of Monstaliner or Raptor, etc, help to literally encapsulate the underlying sheet metal from such moisture ? ... And if the the bedliner is applied in seamless way, and if there comes to be a crack or hole or breach of the material - could I not notice such, and properly repair the fault or imperfection ?
As a side note : I'm wishing to apply LizardSkin Sound Control & Heat Control on the inside and underside of the tub. I'll likely simply topcoat the LizardSkin product with the Imron paint - and not bedliner material.
Might the bedliner product render the vehicle to "look too much like plastic" ?
People, across the board, historically say, "Keep it smooth." ... But would this be counter productive to a really nicely made, logically thought-out, practical-oriented - -trail rig ?
Your honest thoughts on this "outside-the-box" issue & "rogue" philosophy ??
Thanks in advance -
~Skydog
Thanks in advance -
~Skydog
