On my 79 the exhaust runs on the outside of the frame rail. I didn't buy the cruiser new but i'm almost positive this is the stock routing. It seems the frame tie-in will interfere. I eventually got a call back from Metal Tech and they weren't sure if it will interfere with the exhaust or not.The frames tie-ins are all on the outboard side of the frame. The exhaust is inboard.
Well that's a buzz kill. I was hoping to have a somewhat simple premade method of tying the cage to the frame. Based on conversations here and talking with metal techI can answer #1. My 79 has the original exhaust. It does run outboard of the frame. The dual downpipes cross under from the inside to the outside of the frame just aft of the front spring perch. It then runs straight aft outboard of the frame with the cat and heat shield all in there. Then it crosses back under the frame to the inboard side just aft of the rear spring perch. A frame tie in on a cage would be extremely tight at the DS footwell. I would guess this one would take a bit of custom fab. Doesn’t look impossible, just tight.
Well that's a buzz kill. I was hoping to have a somewhat simple premade method of tying the cage to the frame. Based on conversations here and talking with metal tech I do not believeI can answer #1. My 79 has the original exhaust. It does run outboard of the frame. The dual downpipes cross under from the inside to the outside of the frame just aft of the front spring perch. It then runs straight aft outboard of the frame with the cat and heat shield all in there. Then it crosses back under the frame to the inboard side just aft of the rear spring perch. A frame tie in on a cage would be extremely tight at the DS footwell. I would guess this one would take a bit of custom fab. Doesn’t look impossible, just tight.
I don’t mean to be a buzz kill. Just want to give accurate information and save you the time of buying the wrong parts. For what it’s worth, the metal tech cages that I have personally seen are gorgeous. I have seen them without tie ins and they sure seem pretty robust. Especially with the plate across the rear wheel wells distributing the weight.
