This is my first post here so bare with me. Partol Car Alarm System Push Start System Smart Key PKE Car Security Alarm Passive Keyless Entry Engine Start Stop Push Button Remote Starter Shock Sensor Alarm Universal for Most 12V Cars https://www.amazon.com/dp/B07KR1M9CC/ref=cm_sw_r_cp_api_i_DAE3P82JAVCA67CBG5PP?_encoding=UTF8&psc=1
This is the system I bought. There are hundreds on eBay and Amazon, Id shop around and look at reviews cause currently my remote start does work and i don’t know how to get it to work.
Next, to take it apart I used Dashboard Removal and Install - https://forum.ih8mud.com/threads/dashboard-removal-and-install.1225839/
#2, #4 (just the stereo part), #6 and just the first step of #7.
Now insert your key, turn to ACC, push the button in underneath and pull on your key to pull the ignition rod.
Next remove ignition plug which is underneath the ignition cylinder and follow it back towards the engine bay.
At this time, in the ignition cylinder there is a brass tab, I turned it all the way clockwise to the ON position to make sure any bumps or vibrations won’t turn it from the ACC to the OFF position cause that will lock up your steering. Just use a needle nose to turn it.
Next I cut the ignition harness connector plug and wired up the corresponding wires from the push to start module. I thought about tapping into the wires and keeping the plug, plugged in but I was unsure what that would do and if it would cause any issues.
There are two 12v constant. I only use the red and black one. Again I’m unsure what would happen if you used the other one or both, I will most likely go back and attached the other 12v wire.
Next, I set up the old transponder, immobilized and ignition ring. I took off the light bulb from the ignition ring and disconnected it lower in the wire path. Then took the clear part off the ignition ring.
