Buzzard Gulch is clearing out the 1 gallon single tank models for $199.95 + shipping. They have the two gallon twin tank listed on E-Bay for $249.95. However it is pretty bulky for my needs. Buzzard Gulch Tools Homepage
Mr. Brown delivered my compressor today. Picked up 20+' of #10 landscape wire from the home depot. Kevin, Michael; what did you use to attach the short leads to the landscape cable? I'm going to Napa tomorrow to get battery clips for the other end. Any advice appreciated. Thanks, Jim
For a strain relief, I tied a knot in the wire inside the switch box. If you use the supplied wires, remove the switch cover and inspect the connections, one of mine had a connector that was much too large and not making good contact.
My original plan was to permanently mount it in the rig, but there have been a couple of times when other rigs have had issues on the trail that I couldn't drive to, so having it portable is an advantage. I don't see the advantage/need to remove it every time I want to use it. It has worked very well like it is, often airing up multiple rigs and a couple of on the trail air tool wrenching sessions.
Currently designing a quick release mount. Then the rig will be wired for it, with connector to remove from the rig and connect to the extension cord.
Please post up your solution on the quick-mount.
... I'm going to try and find some room under the hood to mount one.
Anyone ever see an oasis mounted under hood on an 80? If so, please post a link.
thanks
Dana
