ive never once worried about engine rpms with the 1FZ as long as your truck is in good condition.
the 1FZ will run forever as long as you keep oil in it and pee in the radiator.
and run it til the valves start to float, then shift.. no tach necessary..
a
Not going to happen, for sure on an OBD2 rig, but believe all of the EFI motors work the same. Not far after red line, the ECU turns the fuel injectors off, until a more sane RPM is seen. Don't know the RPM, was a bit too busy to look, the one time that I did it to mine!![]()
BlackLS1 said:just tried going up the steep grapevine hill on the i-5 and i overheated past the red with a modified temp guage, i was doing just fine by pulling up this hill in 3rd at 80 mph but i thought i would give 2nd gear a try this time after reading this thread and now im worried about a leaky headgasket soon![]()
jcope said:If you were able to go 80 in third, then there would be no need to shift to 2nd. You didn't need the extra power. Downshifting when you're going that fast is just truck abuse. Watching the needle go to overheating without doing something about it is, too.
Not sure how long your grapevine hill is, but if it's at all long and steep like you say, I know mine wouldn't be doing 80.
LandCruiserPhil said:After looking at the data for the grade of Grapevine Hill it should be no problem.
The grade in the video (7%) is steeper then Grapevine (max grade 6.7%) although 2 miles shorter an 80 in good shape should be able to pull it at 65MPH with AC on in 100° plus temp.
It doesnt not add up![]()
Nice job!! If there was an engine swap I would do on an 80, I would put a 2uz-fe in there. What a great engine it is, power, torque and a very long life.
With the 10% and 37's it should be close to the same as me with 35'sOld thread revival...
Thinking of installing the Sumo gear underdrive in the Tcase. 93 FZJ80, stock axle ratio (4.11) and 37 inche tires (rubber overdrive). If the underdrive reduces the final drive ratio 10%, the final drive changes from 1.0 (stock) to 1.1 (with underdrive). Plugging those numbers into the grim jeepers gear ratio calculator Gear Ratio Calculator reveals the following: The speed in each gear at a given RPM is shown below. The first screen dump is the stock Tcase gears, the second screen dump is with the underdrive gears. The RPMs I've selected are 750, 3000, and 4200. The question is, at 4200 rpm (max torque of the 1FZ according to Tools R Us post #21 on this thread), the truck travels slower in second gear pulling long mountain passes (like the one LCP did at the start of this thread? So the Underdrive will make the truck slower (7mph slower at 4200 RPM in second gear)? Or do you tend to just rev higher? Any opinions on experiences with Tcase underdrive on long hills? I'm probably over thinking this. Thanks and take care out there...
Stock Tcase gears:
10% underdrive Tcase gears:
