PTO Winch on a BJ70
I was wondering if my 5 speed, BJ70 comes with the hook ups on the tranny for a PTO winch?
Just Curious
there is a 95% chance you will need the PTO gear in the t/case and you should be set to go...
cheers
how much and where could I find that?
How crazy is it to do?
the job is not that big, just drain, tear apart, stick in gear FACING THE RIGHT WAY (right Bruce?) and reassemble.
i think i have one here but i am sure G&S have a few kicking around, they even have a couple PTO winches around...
cheers
crushers said:
...stick in gear FACING THE RIGHT WAY (right Bruce?) and reassemble...
It works annoyingly well the wrong way.
Annoying because it works fine on all the tests including pulling Tippy out of a hellish mudhole in Alaska called "Greater Satan" but the 1/4" interface on the gears will prove too little on your first real date with the girl you've been stalking on the internet and are completely smitten with resulting in a period of awkward silence while you frantically wait for your buddies to come and rescue you.
Yep, Annoyingly well.
What the heck is that all about???
i will let Bruce tell his story but i was amazed at how much strength 1/4" of meshed teeth has...
