Builds Project - EffjJay Eighty - 2UZ powered (5 Viewers)
Thank you Overlander 80 - I know we've talked before, but I dont recall where your located. You in WA ?
Alright, so I got the ABS relo kit from Marks4wd courtesy of my VERY generous friend Eric. I appreciate it bro.
The kit came well packaged, with almost all the parts to do a knuckle service. I had just serviced them, so I didn't use some of the parts.
The backing plate gets removed and replaced with this revised trim
Heres the mount for the ABS sensor - a little bit of the material has to be trimmed off the knuckle to fit this guy on here.
I should note, I have a problem with these two bolt heads rubbing on the reluctor ring plate and I need to go back and trim them.
This guy gets heated up and dropped over the hub assembly. It will need to be removed when the rotors are changed. I have no idea how ill get it off there...
Then the reluctor ring/plate gets mounted to the hub adapter
The whole assembly ready to rock
I don't care for the fold-able star washers that get sandwiched between the spindle nuts.
So I got the TG chromo's with lock ring. They are BA, hopefully they'll hold up.
I also did the TG hub stud kit since 80% of mine were stripped.
And a set of the aisin hubs with circlip/birf mod
Someone had already swapped birfs on my rig apparently because I had two different drive flanges.
With the aisin hubs, I needed to make the circlip groove closer in. I made a spacer to allow the outer clip to remain on without machining a new groove... but the hub hits it so I had to pull them and machine the groove anyway...
Machined it down to slide over the birf
kudos to all your effort on this.
after seeing this.... i'm even MORE reluctant to swap over to manual hubs. Probably just shelved the idea all together.
You don't have to do the ABS relo to do the hubs. You may have to mod the birfs, but its easy.
Technically you don't even have to remove them.
Canton, Ohio. Was living in Vermont when my first cruiser quest began. Gotta agree with concretejungle about not doing the part time kit now, particularly if the efficiency doesn't change much. Your detailed build documentation is really appreciated, it's what made the creation of my truck successful.
Thanks guys ^
Here is my next extremely high profile mod that I did this past weekend LOL :steer:
In all seriousness, i'm pretty stoked with how it looks now. I already had a cruiser guy at the parts store ask how I did the conversion.
They are nasty and full of grease from before I rebuilt one of the axles
Center punch this in the dimple that's already there from the mold
Drill that guy out with a small pilot hole
In prep for the big dog
They turned out sick and with a tiny-tiny bit of trimming they snap on better than before :bounce:
Generally not a fan of the plastic center caps...but kudos on your creation; they look nice!
