A little background on my 76 I bought this summer and the issues I am having.
The idle has always been high and erratic and in my attempts to correct this I have ran into some issues. PO had installed an HEI w/vacuum advance. The advance was coming in as soon as she was started. I rerouted the vacuum, line to #6 on the VSV per my Haynes manual. This seemed to correct the advance coming in as soon as I started her. I put a vacuum gauge on her tonight and #6 does not pull any vacuum even when I rev the motor? Is there a better source to pull the vacuum from?
While I had the gauge out I tested the vacuum at the port located top front of carb. I'm lucky if it pulls 11 inches. I also tested the port on the manifold directly in front of the carb and this pulls 17 inches. What should my readings be at sea level (delaware)?
I have rebuilt the carb but have a question about the vacuum choke pull off. Should this activate as soon as you start the engine? How would you adjust the fast idle screw if it does not line up with the stop? It lines up fine as long as it is not activated. What is the purpose of it anyway if you have a manual choke?
I really cannot enjoy her until I get these issues resolved. Should I just de-smog her? She passed inspection fine.
John
John
