I can tell you right now you won't be leaving any LED overheads on by accident-those things are BRIGHT!!
Yep. Only thing I would add is that you should FINISH any modifications at least a month or two before your trip so that everything will be sorted out well before the trip.
I never do any repairs or mods before a trip. Things like your dual battery should be done now so that any problems will surface near home and not on your trip.
10k isn't that far, I wouldn't hesitate to do that tomorrow with my vehicle. And you've done more PM than I have. Other than my exhaust rattle that would annoy me to death I would be okay. And so will you.
Spares I'd consider:
- quart of oil
- fusible link set
- EFI relay and a few spare fuses.
Everything else is avail from a Toyota dealership with minimal delay, so I wouldn't sweat it. I would probably drive into a Toyota dealership half way thru the trip for a lube service with tire rotation and quick inspection. But be aware that some techs get carried away with recommendations.
Nice work - only suggestion I'd make is to consider braided stainless steel brake lines if you're going to replace your soft lines anyway. Slee makes a great package on those...at least he used to a few years ago.
I did a bit of research on these. Most were not happy and recommend sticking with OEM lines. That's my next project. I'll be using OEM Toyota lines from other trucks to achieve the extended length. Figure if the originals were good for nearly two decades you can't go wrong with OEM rubber...
I can tell you right now you won't be leaving any LED overheads on by accident-those things are BRIGHT!!![]()
If it were me, I'd definitely replace the springs before you go. In the 14 or so years that I've owned my '94, worn out springs are the only item that cut a trip short. I had about same mileage then as you have now and was fully loaded and in Canyonlands in Utah near the Maze. Tailpipe was banging on the panhard rod on every bump. Ordered new OME spring kit, the week I got back. Your airbags may help, but I'd hate to rely on them with worn out springs. Stock height would be a piece of cake to replace with no castor bushing mod to worry about. Good luck.............Shocks are new OEM Tokico - with original worn out springs. I have Air Bags in the rear. Plan is to swap in 8261 and 8262 OME Stock Height springs soon............
I don't know if you have ever thought of an after market bumper, but it might be something to consider. The country you are traveling through has a TON of deer that can end a trip quickly with a factory bumper. Just a thoughtcheck caliper bolts occasionally - they reportedly come loose on washboard
]10-4 on keeping the DS lubed. Forgot to throw in new U-Joints as well at 160K.
I have gone back and forth on a RTT but I think I am going to build a full lenth low profile sleeping platform and pull the rear seats.
Just did a 4k+ trip over two weeks. It was supposed to be 5k over three weeks but my little brother got sick.
No major issues whatsoever just little annoyances.
. It arrives in a few weeks. Im running a stock 1FZ-FE - but Im sure I will wish I had your SC setup. ]
Have you considered hammock camping instead of platform or tenting it. Once you hammock camp, you never go back.
