Im getting closer to completing my v8 swap and have now come across a problem with the steering shaft and Saginaw pump being in the way.
I have a 1978 sbc block with the stock pump brackets and a saginaw PS setup
Can I mount the pump up high with different SBC mounts ? or maybe on the other side ?
Use a 2 part steering shaft ?
Move the motor back closer to center ? 1/2" would probably do it...its over 1" now to the drivers side (gm center dump rams horns)
I really didn't see this one coming and am pretty stuck for what the cause and fix might be.
