- Thread starter
- #21
nice thread. i use a siemens 90watt panel>charge controller>deep cycle and can verify that it will run indefinitely.
Cool, feel free to post up your set up here
In my truck, I run a system with:
-dual battery system with Odyssey 2150 (100ah) batteries
- magnum energy 1000w pure sine wave inverter/charger (I plug the truck in if I'm not driving it for more than a few days - and everyone thinks it's a hybrid!
- a solar controller with 52W brunton foldable/portable panel (for when I'm parked in remote areas for more than a few days). The panel delivers a rated 3200 mA and even in real world conditions will power the fridge (below) 'forever'
- FridgeFreeze 45L vaccine fridge
So Phil, just out of curiosity:
55W max output at 21V = 2.6A
8 hours in sun at let's say average 80% efficiency (~2.1A) gives you 16.8Ah; 100% efficiency gives 20.8Ah
Numbers on the cooler website say 0.71Ah/h to keep box at 41F with outside temp at 90F, maybe you'll need 20% more for 33F box temp, so: 0.85Ah/h
For 24 hrs: 20.4Ah needed, so sounds like just about even
What does the controller do in the whole mix?
The Expedition Portal has some good info on solar panels and fridges. See post #11 from 'elcoyote', which may apply to less sunny areas than AZ, which means you need more panel area than sunny AZ.
Solar panel to recharge battery from fridge drain?
Phil how many watts is your solar panel rated at ? I am guessing 45 watts ?
.Question for you Phil. I am ordering a solar setup a the moment. What is hooked up to the "load" terminals on your controller? Also do you think the PS30 is needed or will the PS15 work?
Another solar question for you. I got my PS15 hooked up (still deciding on panel) through my rear fuse panel. What are you doing with the controller during downtime while parked at home? Do you turn it off or leave it on? Have you tested the power draw of the controller? I also have a NOCO gen2 battery charger that I Am going to install that would negate power draws while parked at home.No problem with the PS15. You can get by with a lot less of a controller. I use its feature that provide me with info.
I use the load terminals to measure power usage.
