Impressive. If you send it to me I can anodize it with the stuff I send out every day. I usually do black, but I've got a job coming that will require red and gold anodizing. It'll probably be a month for the colors. Black would probably dissipate heat the best.
I don't think you've increased cooling much. You've increased surface area a bit, and changed steel to aluminum, but the thick aluminum may not transfer heat as readily as the thin steel. My aged BMW has a PS cooler, that would be helpful. You could run the incoming fluid through finned, aluminum tubing to dissapate some heat. I can't find my source of finned tubing this morning, but it's available somewhere. Even a coil of smooth aluminum tubing would get rid of a fair amount of heat.
