the fan is in series with power steering gear box outlet, meaning the outlet pipe from the power steering gear box goes in to inlet of the fan and the outlet of the fan returns back in to reservoir.
My pump is not a FJ 60 pump but rather 22R engine pump which is not much a different than 2F.
based on my observation, the fan speed is constant above 1000 rpm and turns low so it does changes once you increase the rpm above idle however, fan turn 4 time faster in idle meaning that the hydraulic pressure must be higher in idle than higher rpm
Dude, there are a bunch of variables in your system that were not even close to being covered in the first post. Before you get all grumpy, lay out the problems and the configuration of what is causing the issue. If you ask a question and actualy give the data needed to answer the question, you will find this place pretty easy going. Were some of the comments not the nicest? Nope.. The was no way to "understand" your setup to give you an answer with the info you have given. Even now troubleshooting is complex because you have a fairly oddball setup for a LC 60 section.
Is the hydraulic fan designed to run low PSI? Routing it after the Steering box (in series) gives you a significantly lower psi rating than directly off of the powersteering pump.
Stock pump values mean nothing after it has traveled through the steering box..
Hydraulic winchs, Brake boosters, etc, are designed to run at full pump PSI. So you would route the system in parallel to the steering box, not series. If your pums is designed to run low psi, there may be other problems still.
