I am trying to get a sense out of how much pressure the power steering pump puts out during idle on a FJ60 and if the output pressures decreses with increase in engine RPM.
~1500 psi IIRC
And, why would output pressure decrease with an increase in engine Rpm?
cause my radiator fan of the FJ60 runs with output oil out of power steering rack before it goes in to reservoir so at idel ,my fan run faster but when engine RPM increases, fan speed decreases.
So I am guessing, there must be a check valve inside the PS pump that reduces pressure as engine RPM increases.
Is it only me that dosn't get one bit of this?![]()
If it is a hydraulic motor running the cooling fan that would be kinda neat. It looks like they make motors that would work, might be easier than electric, aside from the extra work anyway.
Hydro-steer
Hydro-brakes
Hydro-cooling??
That's the first one of those I have ever seen.. Cool
As posted above, Flow/psi should be regulated by the pump pretty well. I cannot see any reason why the fan would slow with higher RPM's.
Does the fan slow when you steer the truck as well?
Is that a diesel specific thing?
I had no idea they were as common as they apparently are.. VERY cool.
Is the pump system dumb? Meaning does it just flow whatever the PS pump puts out? Or is there some sort of valve that is regulated mechanically or by a computer of some sort? Apparently there actually are commonly inverse-acting proportional pressure control valves used in this type of system. And that may be what you are seeing. If it is a mechanical or computer controlled system, what you may be experiencing is the speed of the fan is designed to vary with engine temp, so if the coolant temp is transferring through the radiator at a faster rate when you add rpm's it may not get as hot as it was at idle. So the fan would run slower. Course I am really talking out of my butt on this one since I have not seen a setup like that ever on a LC.
BTW, nice ferd parts
More details of your setup would be cool![]()
