Hi All -
When I bought my truck a couple of thousand miles ago, the overflow / reserve reservoir was completely empty. Since then, I have changed the water pump, etc. which meant replacing the coolant. In addition, I pulled the trans cooler lines when changing the starter which meant I got a coolant shower and also the privilege of adding another gallon or so of coolant to top it off.
Since then, it's been dropping about 1/8" below the full line in the reservoir about every 100 miles. Granted, I've only driven it about 250 since then so it could be bubbles working themselves out?
I don't have any coolant leaks that I can spot. Think it's just bubbles and give it a few hundred more miles or start looking for more serious coolant consumption causes?
Thanks!!!
Thanks!!!
