Good ideas, thanks! I like the idea of bending it straight, even if it makes it more difficult to use. Even if I remove it before running trails, having it straight protects it for the times I forget to remove it.
I think that's exactly what I'll try.It would be clever to make a folding mount with just enough resistance in the hinge to keep it folded up when not purposely folded down.
E Load or D?Not my damage per say, but saved a buddy from not 1, 2, but 3 tire failures this weekend. 1 tire absolutely destroyed. 2 tires just popped beads that the LX dual Viair OBA was able to re-seat. Of course the popped beads happened in a pinch where he simultaneously lost both rear tires and was outright stuck on sliders.
Where this is relevant for the 200-series is probably the LX that has similar stock 20x8.5 wheels sizes to the F150.
PSA - don't run a 275 width lower profile tires on a tall wide wheel, as many LX owners seem to do. Namely a 275/55R20 on an 8.5" width wheel. At 20PSI, tires failed all too easily. IMO, needs more sidewall height either by taller diameter tires or smaller diameter wheels. Also, poor mans beadlock is a thing, and for a 8.5" wide rim, really need 285s or wider.
Got a little to complacent this weekend and came off a rock faster than I should have. Also glad we were driving back in a convo or I wouldn't have the Tupperware anymore.
He did replace the bumper and posted:Have you replaced the rear bumper with something more stout?
I have to say, Sonora Gold is my favorite 200 OEM color code. Great looking truck w/ the lift and rock warrior combo.
Yup just recently slapped a trail tailor rear on there. Leaving for Utah next weekend to bash it up!Have you replaced the rear bumper with something more stout?
Not mine. Not sure that snorkel's going to help much.
Kept hitting the control arm mounts. I hate that they extend down a few inches below anything else. I guess I need some skids for them.
View attachment 2970010Yep. Get the Trail Tailor skids.
@TRAIL TAILOR is this supposed to slide on easy? I had a very difficult time. With the stock mount flaring out slightly at the bottom, and the sides of the stock mount not being flat, it really took a lot of pounding to get the skid on there. One of the self-tapping bolts broke with little effort, too (tightening by hand). It seems impossible to get the leading plane to sit flush against the frame (makes me think that any impact is going to compress and likely break the length of those two low-strength bolts in the gap between the front of the skid and the frame).Ordered. Maybe I'm lucky, it seems @TRAIL TAILOR is the only one that makes these for the 200, and it's hit or miss is he's recently made a batch. Only 3 sets left in stock on the website.
I only installed one side because now I'm unsure if this is actually a good fit.
Here's the interference on the outside driver's edge, doesn't like to slide past that protrusion:
Pounded it past that, but this is as far as the frame allows it to hinge upward:
