Possible small Hamons in Dec at my place.
Ok, no problem, definitely understandable. I apologize for the fasteners getting mixed up. I should have kept better track of which ones came out of my truck and which ones came out of your truck.
Other parts ok?
Yes everything else is good to go eh.
Not your fault with the bolts and stuff as it was in the tray next to your truck, should of just taken and put them somewhere else for the time being.
That's all I found missing thus far. As I put stuff together I may find more that's missing. Couple of quirks:
- Beeper comes on for the first 5-7 seconds of turning the truck on. The same beeper that goes off if you have your keys in the ignition (truck off) and open the door
- Blower fan only works on high
- Exhaust has separated from the header ( not body swap related, still annoyingly loud though:hillbilly: )
That's it so far.
Exciting news with regards to the windshield. Eric set me up with Will from Absolute Vision. He came out and installed a new windshield 30 minutes ago for $200!!! That's half of what it cost with the other companies. He seems to be a good guy and is prompt with his work. I'd recommend him to anyone for their automotive glass needs.
Johnny that truck looks amazing. awesome work guys. Can't wait to see that Raptor liner up close.
I didn't even realize it was lined till I saw it up close in person... from the earlier pics I thought it was just painted white.
Thanks guys:D She did come out pretty well. I've been plugging away at the little things in the interior. Got the blower motor working properly thanks to a post in my ROTW thread from a guy in Norway I've become friends with. Took out all the old speaker wiring so I can wire it in myself.
Darin, I can't figure out how I'm going to fix the heater wires. I tried using zip ties but I can't make them tight enough on the cable to prevent it from slipping out of place. Are you willing to part with your HVAC control panel ( with switches )? How much do you want for it?
What about a small hose clamp?
Good idea. The issue is that the only place to affix the cable sheath is to a small square hole in the bracket, directly above the cable. I was hoping a zip tie would be able to stick up out of the hole and be rigid, but I couldn't get enough friction. I don't see how a hose clamp will work with the small hole.
