In the last couiple of weeks or so I noticed that sometimes my coolant expansion tank is near empty ( almost dry ) and aometimes it's at the full mark.
My dash guage inside the cab always reads just a nick below half and on a hill climb it goes just above half. ( I realize that the guages are not the most accurate ) . The coolant has been changed when I bought the veh. a 1990 LJ71 with the 2LTE motor.
Veh. now has 62000 k's. I only notice a small amount of black smoke on a cold start up and going up steep hills. There is no white smoke at all.
Looking at the expansion tank after a drive you can hear coolant gurgling back into the tank.No leaks noted anywhere, engine bay or on ground.
I read somewhere that if you see bubbles in the expansion tank when you pop the top off that this may be a tell tale sign that you have a cracked head.
Any truth to this. ? My veh. runs great otherwise.
Thanks
Peter
Thanks
Peter
