- Joined
- Jan 12, 2008
- Threads
- 299
- Messages
- 3,586
- Location
- West MI near GVSU
- Website
- www.mcdesignsoffroad.com
I am going to need a centered rear diff eventually and was going to use a Ford 9" with 14-bolt spindles and hubs. Recently I discovered a '95 C&C 14-bolt that could be easily narrowed for the WMS I want using srw hubs I converted to 6-lug. I would also shave the bottom ~2" while I'm at it.
My question for you all is: if I cut off the factory axle shaft drive flanges and made new ones that would press over the cut shaft, could it be safely and securely welded? I have commercial welders available at work. There would be two continuous beads around the inside and outside of each new flange. I wouldn't have to have new custom shafts made. My only real cost in addition to $100 for the housing would be finding the right gear-set and whatever locker I end up with. I'd like an ARB...
Thoughts?
Thoughts?
