- Vehicle Model
- 100 Series
- Location
- Portland, Oregon United States
This is pretty much a plug-n-play setup for a huge headlight upgrade.
I bought these used about 6 months ago with the retrofit already done so a few details are unknown to me. I found these while looking for temporary headlights to use while retrofitted my OEM glass headlights. I would be keeping these but I had not already bought all the parts to do the retrofit mine and I finally finished that project. Now I have two sets of very similar lights. I slightly prefer the glass two piece look, so I'm selling these. This is a great set up awesome set up thought and will save someone a ton of time and money.
Includes
You’ll need
Other things to note
$450
I'd prefer to sell these locally in Portland, OR. I'll consider shipping at buyers expense in a few weeks if they haven't sold.
..oh and please ignore the terrible headlight aiming in the last photo. That was before I aimed them and it's only photo I have of the light output.
Includes
- Depo 1 piece headlights for 98-05 models - one tab is broken on drivers side that attaches to grille. Hasn't been an issue for me.
- Morimoto (I think) DS2 projectors - not sure the exact version number
- Osram Xenarc 6k D2S HID bulbs
- LED high beam bulbs (these can be ran in combo with the projectors with splitters)
- D2S igniters
- Two extra lock rings - Morimoto blue anodized
- Lock ring socket tool
You’ll need
- Wiring harness - I use this one
- HID ballasts
- Possibly new igniters or wiring adapters depending what’s ballasts you choose
- Turn signal and parking light bulbs are also not included but they can be reused from your OEM lights
- Neither projector is glued/permanently attached yet. You can still turn the projectors to get the cutoff aligned correctly. I would recommend JB Welding these once you confirm proper alignment.
- There’s some light water spots and dust inside both headlights. You could reopen them and clean them if it bothers you. Might be a good ideas anyways as it would allow you to more easily tighten down and JB Weld the projectors.
$450
