Poor Heater Performance? Check These Threads! (2 Viewers)
Rigger
Ramble Tamble
Staff member
s-Moderator
Wyoming
These are links to threads that will help you diagnose problems with poor heater performance. I'll add more links as I find them.
If you know of a good thread on this topic, post up. I will add it to this list, then delete your post to keep this thread clean.
(This is my first formal act as your new 60-series moderator, so I want to make it neat and clean!)
Threads:
https://forum.ih8mud.com/60-series-wagons/240255-fj62-little-heat-front-heater-help-needed.html
https://forum.ih8mud.com/60-series-wagons/184960-any-ideas-no-heat-happening.html
https://forum.ih8mud.com/60-series-wagons/338969-very-little-heat.html
https://forum.ih8mud.com/60-series-wagons/98387-another-one-those-no-heat-questions.html
https://forum.ih8mud.com/60-series-wagons/340650-cold-running-62-a.html
How to acid-flush the core without removing it from the truck:
https://forum.ih8mud.com/1657238-post31.html
If you have to remove and replace the front heater core, read this thread:
https://forum.ih8mud.com/60-series-wagons/250350-pics-replacing-heater-core.html
Somebody should sticky this for the winter, BURRRRRR.
Thanks Rigger.
It is in FAQ. I froze last winter. This winter, it's gonna be different!
I have been afflicted with a LONG time in warming up. I flushed all the hoses and both heaters. I had a new thermostat installed and gave both gaskets to the mechanics to put in, but I didn't "show/tell them what needed to be done"
well today, while doing several fixes/upgrades, I pulled the thermostat housing, etc.
Lo and behold, there was no O ring on top of the thermostat - oh my. The guy had left it out.
Well I reinstalled the 82 C thermostat with BOTH gaskets.
Man oh man does it heat up NOW. This is awesome. Can't wait until the commute to work on monday.
That O ring really works
I also installed a new temp sending unit - the old one pegged the meter on super HOT, even when starting in the cold, cold morning.
Put in JimC's altered dizzy. Took of the rocker side access panel and cleaned the PCV stem - it was plugged. Changed oil and filter. Runs great
dougt
Heater full of mud.
I cut the hoses underneath my 60 that run to the rear heater to replace them and found about 8 inches worth of solid mud. the heater core was full too. Used compressed air and water to flush the hoses. and the core. works great now. nasty stuff looked like my sixty had diahrea all over the garage.
