POLL: How many miles you guys average on a tank
about 280 on about 21+ gallons......am going to change spark plugs this weekend....used to get 300+ miles in the same amount of fuel...
According to my Nav Crap I usually get 240-ish. Running 35x12.5's w/no speedo correction or regearing.
I do about the same as Pimp, 25 - 45 mph and a ton of idling.
highway - 500 - 750 KMs (petrol/gasoline V8) depending on terrain and weather (aircon on/off) and i've got the sub tank too which i'm including in this.
offroad - varies, 300 -500 KMs depending on where i'm going
towing a very heavy trailer with two canoes on top in March this year with 3 blokes (including me) on board and a bit of onboard luggage, i struggled to get 400 KM inclusive from both tanks in flat and mountainous highways.
cheers
peter
380 on Highway????? you must be dreaming....my bad you must be talking about your 4Runner..we are talking about the 100 :O))
I said UP TO 380. If you agree that 16mpg is not the best result:
16mpg x 25.4g = 406m. So up to 380 looks wery reasonable number...
BTW, from my observations, to keep your rig top performance and for better gas mileage it is good practice to replace O2 sensors every 75K miles, even CEL does not warn you about.
At that age they do not provide adequate feedback to ECU.
Wow! Some of you guys must run solid tires! I have numbers close to LXRunner and I don't get beat too badly when I'm towing. I piss off my buddies because I go further than them when we tow in groups. (But I do wish I had that Diesel!!)
Jim
i never checked but i guess its about 275 when i got it 300 but that was a couple bumpers and biger tires ago but dont tell my wife i told her its a hybrid and gets 50 mi to the gal :D
300
I usually get about 300 miles on trips, or about 250-275 with mixed. 4.88 gears, 315's and quite a bit of weight. Was a little worse before changing the gears. Was a little better bone stock. When I tow my boat over the mountains I can go 150-175 miles on a tank, pretty bad and $$$.
I think I get 250-275 out of a tank. Not 100% sure as I quit paying much attention since it keeps going down as I add more "stuff" to the truck...:crybaby:
I get about 275 miles per tank with a combination of local and highway driving and about 300+ all highway if I'm driving conservatively.
I use this helpful formula
miles per gallon / gallon per tank = miles per tank
Mileage will vary depending on how each rig is outfitted, weight, tires, drive train etc.
There is no standard.
Hope this helps. :grinpimp:
