Please help identifying this bad noise my 2f is making at high rpm (1 Viewer)
QLD
So just recently my 2f is making a bad noise when i reach a certain rpm. Has anybody had this happen before or any clue as to what it might be. The noise is towards end of the video
Looks like the belt is loose and is slipping at higher rpm's.
Sounds like loose or slipping belt as the fan tries to pull max air at higher rpm’s
Bearing in an accessory is my guess as well. It kinda looks like something is loading that belt hard when the noise is happening too, but I might be wrong on that.
My money is on water pump.
If you tighten the belt it'll probably get a whole lot worse.
