- Thread starter
- #1
Okay...I've rebuilt transfer cases and worked on transmissions for a few years. This is my first stab at ring and pinion work. The dry run without the collapsible spacer went good, all the preload torque values were within spec, good ring gear backlash, and great teeth marks on the face and on the back.
Although the dry run went good, I'm dealing with a challenge. I cannot get the collapsible spacer to crush. I'm fearful I may have stripped the pinion nut. I have exceeded the torque of 250 ft lbs on my torque wrench and moved to a 3/4 inch breaker bar with a 3 foot pipe. I noticed movement on the pinion nut initially and now my breaker bar with the extension is not moving tighter or loosening.
Any ideas and advice is welcomed and appreciated.
