Thanks! Going to experiment and see what I can come up with to use that space.It is a separate module.
Just curious if anyone has tried to delete the phone charger area, looks separated from the module above it with the radio knobs but I have not verified it by pulling dash yet. I could find so may uses for that space.
What you dont like putting 2015's iPhone in there or something?
Will your charger fit in my 17' LX? Ill take it off you if it does. Its the only option i dont have.
If you remove the whole module, it is a pretty good space. It'd be great for a comms install.I see that once you removed it, the space looks pretty small behind that charger module.
I would rather use that space for something else, maybe for my ham radio as that stupid cooler thing takes up all the storage and that thing is a PITA to replace, not sure if it can be because of the AC system.
I thought these were standard, what does your LX have in its place?
You have to do a lot of disassembly to get to it.
Sort of shocking, but the whole center console top has to come off to get it out.
Note that the silver cover is a separate piece that pops off easily before removing the center console. But there is a horizontal brace in the way of taking the charger component out that you need to remove after taking out the console top. I set it loosely back in place to show the general location for the photo below.
I wonder if other markets offer a storage box for this module, maybe on the lower spec versions? Try partssouq.com maybe?
The charging module electronic box takes up at least half of the vertical space. The "cigarette" lighter eats up the left 1/3. There is a lot of space to work with. I am 100% serious when I suggest looking at lower spec ROW models. I'm sure they didn't waste the cost of a charger in low spec models in some geographies. Maybe ask on some of the international groups (Facebook has some good ones).
That is exactly what I was thinking, my ham radio![]()
Was standard for 17 LX's here in Australia and it's still useless as s***.What you dont like putting 2015's iPhone in there or something?
