Don't even fool with the lower bolt. I wasted a lot of time trying to defeat it. Just break off the lower bracket and have your revenge on it.
All you need to do is remove the top hose and top bracket bolt and bend the bracket back 90 degrees and cut the lower hose so you have room to wiggle it back and forth.
From below, cut the hose completely in two with a utility knife and let the fluid drain into a pan. Rotate the lower end of the tube 90 degrees CCW on its vertical axis. to make more room to wiggle it. Don't fool with the hose clamps yet. 10 minutes. If you want to remove the transmission dip stick bracket bolts to make more room for your hand, go ahead, but removing them and reinstalling them will take 10 more minutes.
From the top, rapidly wiggle the tube back and forth about 3 inches until the bracket breaks off. Lift the tube out and cut the clamp and hose from the tube. You can do a step 6 while you are wiggling the tube. 10 minutes
From below, remove the hose clamp with needle nose pliers and remove the hose. This is much easier after you remove the tube because there is more room. 10 minutes
Install 60 mm of hose to the end of the tube and tighten clamp. Put on the other hose clamp and loosely tighten. 10 minutes
From below, install the tube assembly and shove the hose onto the block tube. Tighten other clamp with a gear wrench. This is the hardest part of the whole job. 10 minutes.
Tighten top bolt and reinstall top hose. 5 minutes.
Step 6. 5 minutes. Done.
You can do this in about 60 minutes while drinking two beers.
