Mall cruiser - 80k?
Rock crawling - 50k
What is your opinion?
Rock crawling - 50k
Mixed use ( commuting, rock crawling )- 85-100K. Towing heavy consistently - 60k
Hmmm. Where are you sourcing your fluid? Dealer only?
Thanks!Online Toyota dealers and amazon both have it.
Is there a DIY? Looking to do this on my 2011. Thanks!This.
I’ve done it now twice on my 4Runner with 185k and will be doing it in the LX this summer at around 90k. It’s so easy.
This is a great video. I ordered 12 qts of Toyota WS from Amazon.
Years ago, when WS just came out. On the bottle it said that under severe service that WS lasts 60,000 miles.
It has since been removed from the bottle, but VOA of the stuff from then to a couple years ago when I did it again showed it to be the same from what an analysis can tell. (There are deep things that we will never know that can be found in an analysis)
So for me, 60k intervals regardless of use. Fluid is cheap, drivetrains are not.
For more fun, I’ve done UOA on five WS trannys. Three A750Fs and two AB60s, for 13 total UOAs. The first 60k miles on each was the worse, because of the break in process. After that, these transmissions (just like Toyota engines) are pretty gentle on the fluid. So I know that at 120k, 180k, ect, it’s overkill. But I always figured if I can afford a car, I should also be able to afford it’s mainenance.
Are we sure putting The second cooler line into a container of clean fluid will actually draw it into the transmission? I was under the impression it had to be pumped/fed into the case via the fill port one pan volume at a time.
