Performance Chip for LX 570????? (2 Viewers)
Columbia SC.
Anyone have one??? IS it worth buying? Did you notice better milage/power?
I pull a Jon boat and atv sometimes. Interested to hear feedback. Thanks
The OEM power of the V8 should be plenty for your towing needs.
But I get it you cannot have too much power.
Unfortunately Toyota ECM is locked and not easy to break. Add to that that unless you have a turbo engine and/or you made modification to it, there is not lot of power left unused in a modern engine from the factory. You may gain more but it is going to be at the expense of reliability or longevity.
I personally stay away from chips for NA engines. And on force induction I'm very careful on selecting the co. I'm working with. I do own a modified turbo car running custom maps. I also have modified tune in a NA Outback but it has modifications that the tune takes advantage.
Having tuned ECUs before... this may not be what you want to do because the nature of towing requiring prolonged outputs and getting into heat soak constraints. I'm all for turning up the wick as I do in my sports cars, but not for towing.
There's generally two major dials to get more performance: timing and air/fuel
- Advancing timing puts more heat load on the engine and will start bumping into heat soak, octane limitations, and knock. At which point the ECU pulls timing and you're back to potentially worse than stock power output
- Leaning out A/F can make more interim power, but the reduced fuel creates less cooling of the combustion chamber at which point manifests in heat soak, knock, pulled timing and again, potentially less power than stock
There is no free lunch with sustained power and the engine has to be designed for it from the ground up. It will definitely compromise reliability trying to make more N/A power via a tune.
I monitor the stock ECU and transmission and as it were stock, with high towing loads and extended engine outputs in hot weather, the ECU will begin to trim timing and output. Same with the transmission, the more power you put through it, the more heat there will be and even with the great aux cooler and an added aux cooler, can experience heat soak limitations.
Many new to towing assume torque, and drive torque, as that's been parroted all too often. That's only half the truth. Torque (and gearing) gets you off the line. Once at speed, it is all HP. What I'm getting at is that it's important to access the broader RPM. Driving below say 3500RPM, only opens up a bit more than half the power of the 5.7L. There is easily another 30-40% power on tap at the higher RPM ranges. When I'm talking about heat soak with towing, it is sustaining that output, running 4500RPM++ for 20-30 minutes at a time in some of the most difficult grades of the Rockies and Sierras. The 5.7L is up for it, designed for it, and power can be had reliably when using the tool as Toyota intended it.
That said, what are you intending to tow? I tow 8k lbs and the engine makes plenty of power to keep me with traffic, even in major grades. It can also drink a ton of fuel so there is a trade trying to make more power. A better mod may be an auxillary fuel tank.
No need for a chip for what you tow. Turn on ECT PWR and go.
If you’ve changed tires and have other mods you might want to re-gear to improve torque response off the line. That’s $2500-3000 though
If you really want more towing power you need the magnuson supercharger. That’s $8k+ though.
Shoot, for THAT kind of weight, I heartily recommend an F550. Best not risk it.
I've never tried a performance chip, but I just did the OTT tune. Absolutely worth it, makes drivability way better.
Based on their website it's about an 8% torque increase and probably a 4% total horsepower increase. Most of it is below 2000 RPM. Best $400 I've spent.
How much did it cost all-in?
All the authorized retailers have their own pricing but are relatively close. Finding the nearest one and scheduling a tune is easy.
Edit: Looks like in your neck of the woods, it is $600.
