PERFORMANCE BRAKE ROTORS AVAILABLE AT WWW.DUISER.COM INCREASE YOUR STOPPING POWER!!
360 PERFORMANCE ROTORS-MACHINED IN THE USA
Our rotors are a premium performance replacements for your Stock/ OEM/ OE brake rotors. No vehicle modifications are required, simply bolt on. The perfect upgrade for improved vehicle stopping power! 360 Performance Rotors meet and or exceed all industry safety standards.
http://www.360performancerotors.com/
DRILLED AND SLOTTED FOR OFF-ROAD APPLICATIONS
Not sure about drilled and slotted rotors off-road? Consider that 90% or more of your driving is on the road where you need superior braking performance most.
• Increased dissipation of water, dust and road grime from the contact area of your braking system.
• Improved integrity of the pad and rotor surface, through deglazing of the contact area.
Directional slotting surface also combats “out-gassing” which is caused by gas from the brake pad bonding agent forming a cushion between your pad and rotor and thereby reducing pad “bite”.
ABOUT
Using premium rotor blanks and state of the art machining processes, 360 Performance Rotors meet and or exceed industry safety standards. 360 Performance Rotors utilizes proprietary cross drilled and slotted patterns maximizing out gassing and heat reduction for increased braking performance. All 360 Performance Rotors are zinc plated silver standard, black and gold options are available. Zinc plating prevents brake pad glazing and corrosion for longer rotor life.
3 YEAR WARRANTY
360 Performance Rotors have a 3 year warranty against manufacturer defects. Warranty is valid from the date of purchase provided that the product has not been subject to abuse or misuse in its use or installation, or has not been subject to modification or alteration. Warranty does not cover normal wear and tear or damage caused by negligence, lack of maintenance, abnormal operation, track racing, off-road use, or improper installation. All warranty claims require a proof of purchase, and must be approved prior to being returned, and customer will be responsible for the return shipping cost. Any compensation for warranty claims, will be in the form of product replacement, or store credit. No additional fees for installation or any other cost will be reimbursed with a warranty claim.
360 Website
80 Series Brakes
WWW.DUISER.COM
100 Series Brakes
WWW.DUISER.COM
ABOUT
3 YEAR WARRANTY
360 Website
80 Series Brakes
WWW.DUISER.COM
100 Series Brakes
WWW.DUISER.COM
