- Year
- 2008
- Vehicle Model
- GX470
- Mileage
- 245000
- Color
- White
2008 GX470 - $19,500 OBO
VIN: JTJBT20X080165810
~246,xxx miles
Feel free to reach out to me by email with questions.
ericmunns@gmail.com
This is your next, turn key, everything done for you, fully built, adventure rig. Just add fuel and this will take you safely and comfortably to the Artic Circle and back starting tomorrow.
We've been loving and building this truck since we bought it in 2017 and we're not 100% happy to see it go but that how life is. We only hope it goes to another happy adventuring family.
Here are the highlights:
Wheels, tires, suspension -
SCS F5 wheels - 17x8.5
BFG A/T KO2 285/70 R17
SPC Upper Control Arms
Dobinson’s front MRA standard travel coilovers (C59-352)
Dobinson’s Rear MRA Long Travel shocks
Dobinson's 749v 3” LT rear springs, 700lbs+
Airlift 1000 rear spring airbags
Wheeler offroad bumpstops, front/rear
Armor & protection:
Rocksteady Motorsports aluminum skid plates
Pelfreybilt hybrid front bumper
Coastal Offroad rear bumper, single swing out
Metal Tech, OPOR(outpost off-road) - Sliders
Gobi roof rack & ladder
Storage & interior:
Orangebox rear window molle panel
Rear door, BROG Velcro panel w/ zipper bags
Outback adventure drop down table
Raingler nets rear & second row attic
Raingler nets dog barrier
All interior lights to LED
GROM V-line 2 infotainment- Android auto/ Apple Carplay
Fun stuff:
Switch Pros 9100 controller
ARB CKMA12, single, air compressor
ComeUp SEAL GEN2 9.5rs, synthetic 100’ line
WAT Nomad Valve body upgrade
Motorcityremotes remote starter
Trail Power Hoodie- solar panel 120w w/MPPT solar controller
RedArc Tow-Pro Elite brake controller
Front & Rear GX460 axle swap to 3.91 gears w/ TJM air locker (rear)
MBP ECU Tune
Doug Thorley long tube headers, Brockett Built y-pipe & muffler
LRA 24 gallon auxiliary fuel tank
*Water pump/ Timing belt last done Aug. '21 @ ~190,000 miles
Full Completed Mod list:
-Rear hatch gas strut conversion (SE244P40M10)
-HID headlight conversion, H11
-BFG A/T KO2 285/70-17
-Weathertech floor liners
-SCS F5 wheels - 17x8.5 , 148,xxx
-All interior lights to LED
-CBI ditch light brackets(white)
-Rigid Marine Dully LEDs - Flood (white)
-Switch Pros 9100 controller
-G8 LED 9005 hi-beams
-Power Tray bracket
-ARB CKMA12, single, air compressor
-Raingler ceiling storage net
-SPC UCA -150,000miles
-Blue Sea dual USB charger
-Rocksteady Motorsports aluminum skid plates
-Rear Blue Sea 4.8A USB port
-Orangebox PSDs
-KC Cyclone rock lights
-Yodateq engine compartment light kit
-Outback adventure drop down table
-Gobi roof rack
-Gobi rear ladder
-Metal Tech, OPOR(outpost off-road) - Sliders
-Powertanks 6lbs propane bracket, 1.4gal aluminum tank
-Fumto oil drain valve F103N
-Pelfreybilt hybrid front bumper
-ComeUp SEAL GEN2 9.5rs, synthetic 100’ line
-Airlift 1000 rear spring airbags (46151)
-SR-Series PRO | 20" Spot/Flood Combo
-Two E-Series PRO | 6" Spot
-Rear LED flood lights
-Raingler nets dog barrier
-Snorkel
-Tacoma washer spray nozzle
-Window Tint
-PCK(Panard correction kit)
-Group 31 Odyssey AGM battery
-Xplicit Audio battery terminals
-LED Door puddle lights(KC cyclone)
-Alpine sport snow chains 2327
-GROM V-line 2 infotainment (2/18/19)
-BAFX, OBD II reader w/ Torque App
-Coastal Offroad rear bumper, single swing out
-Rear bumper LED reverse lights
-Flush Mount trailer wire plug
-Blue Pit wheel bearings (7/15/19-169,000)
-GM diode 12135037 (voltage booster)
-Rack mounted Side flood lighting
-Rear door USB/Volt meter
-WAT Nomad Valve body upgrade (170,000)
-Rear bumper folding step install
-Wheeler offroad bumpstops, front/rear
-Relocate rear camera
-Forward camera installed
-Motorcityremotes remote starter (11/13/19)
-Rear stainless steel extended brake lines
-Front stainless steel brake lines
-Proforged T4R rear sway bar end links
-Extended rear diff breather
-CVJ High angle CV joints, (3/19/20)
-Rear door, BROG Velcro panel w/ zipper bags
-Bluesea 12v/usb switch panel (fridge)
-Fridge platform
-Rhinolined rear bumper
-Dobinson’s front MRA standard travel(C59-352)
-Dobinson’s Rear MRA Long Travel
-150amp alternator (8/5/20, 178,500)
-Gobi roof rack, rear step platform
-SmartTap CF18
-Toyota harness 82241-35010
-Rebuilt rear bumper, 4x Innovations, swing out tire carrier hinge
-Xprite chase light 30” RYWYR
-Raingler second row attic net
-Matte black hood wrap
-Trail Power Hoodie solar panel 120w
-MPPT solar controller w/Bluetooth
-GX460 front brakes, rear pads/rotors
-EBC Green pads
-Rear BlueSea fuse/distribution box
-RedArc Tow-Pro Elite brake controller
-12v rear SB175 Anderson connectors
-Center console switch panel: OTR switch guys: seat heater switches, air locker switch, compressor switch
-Rear axle swap 3.91 gears
-TJM air locker (rear)
-Front axle swap 3.91 gears
-Ready Overland rear lower links
-Replaced front sway bar end links
-Doug Thorley long tube headers
-Big Daddies, 90deg O2 spacers
-Ready Overland winch line holder
-Diode Dynamics SS3 fog lights
-LRA 24 gallon auxiliary fuel tank
-Dobinsons 749v 3” LT rear springs, 700lbs+
-MBP ECU Tune
-Front brake pads - 02/04/24
-Hewitt-Tech SAIS Bypass Kit
-Front/rear brake pads, rear rotors (2/15/24)
-Brockett Built y-pipe
-rear o2 sensors (7/24)
-Brockett Built muffler
~246,xxx miles
ericmunns@gmail.com
Armor & protection:
Storage & interior:
Fun stuff:
MBP ECU Tune
-Power Tray bracket
-Orangebox PSDs
-Gobi roof rack
-Gobi rear ladder
-Snorkel
-Window Tint
-Fridge platform
-SmartTap CF18
-EBC Green pads
-MBP ECU Tune
