Anybody seen / done such a critter? <ducks>
You're correct about the spring spacing in the front, I would have to position new spring brackets outboard of the frame rails. Might do the same in the rear but they appear to be wide enough apart as-is.
It is my intention to end up with a Dana 60 front axle and a GM 14-bolt full-floater in the rear end. I have the rear end now but have not yet collected the front end, transmission, transfer case or wheels (I am thinking a GM TH700R4 and NP208 running behind the F155 and 36" HMMWV double-beadlocks)
For a D44, I have been looking at some 5.13 gears on sale and some 5.89 gears _not_ on sale. I am not sure how low the D60 and 14B can go.
The setup I end up with in the front should be an easy swap from the D44 to D60, will be setting everything up with that goal in mind.
Hopefully this would last a year or so until I can collect the rest of the beefy stuff!
fj40charles raises an interesting question to me... How many folks put a big, centered diff in the rear while still running the Yota offset transfer case? Would I be asking for trouble with driveline angles if I push the rear axle back a couple inches? If that can be done I would just skip the rear D44 altogether and go with the 14-bolt and install the auto trans later.
Lowest gear ratio on a 14 bolt is 5.38. IMHO, the best option (usually most expensive too) is to do the conversion all at once. Go with a centered rear diff. Do the auto conversion with a new centered transfer case.
What is the F155 engine? I hope you don't plan on running a stock 6 cylinder. Your driveline angles will be real short behind a 700/r4 and np208.
if your goal is a 60/14 with an auto, just do that...
Im so sick of spending money on my rig, just to tear it out in a year and replace it all..
keep it the way it is, gather your parts, and do it all at once, that way its right the first time.
For the transmission...Good luck mating up a 700R4. I think Mace has the only known adapter, and the people who made it couldn't get it working.
You could install the automatic out of an FJ62, the A440F. I don't know what transfer cases you could mate up to that to get a center rear drop.
