Passenger Fuse Box
Lubbock, TX
Hey All,
I'm looking to wire up my MXT275 radio in the glove compartment. I'm looking at the Fuse Diagram and fuse 5 is a 15A fuse that says "DOOR DL". What is that? In the circuit it says "No circuit". Thinking of running a fuse tap but not sure what that is and if it's on all the time or with the ACC ignition. Getting out my multimeter now for that last thought.
Post what year you have (and consider putting it in your sig.) I’ll do some digging in the ewd
Door DL isn't even listed in the EWD, presumably because it's not a live circuit. I'm not even sure if it would have a positive lead in the block to tap into.
I did a bit more digging and it appears none of the circuits in that box are wired to accessory. All are either constant 12v or ignition switched.
Pretty inconvenient.
So I wired up to it. It provides 12V power after the car is on. Electric stage 2? Idk what you call it but just before the engine is on
Probably Ignition on.
