For Sale Parting Out: '78 & '74 FJ40s
All PMs returned. Thanks
im interested in all the seat brackets on the 78 for sure if they are solid, the doors for 40 each if they are the rear doors/ with hinges?
body tub condition?
any front turn signals?
any seats front or rear?
do you have the gastank cover?
how much ?
body tub condition?
how much ?
Sorry, but I don't have any of that stuff.
Are thise doors still available? If so can you possibly post pic's.
Cheers,
Brian
Yes, but shipping to Alberta would be a killer.
Lots of nice parts left...
Updated availibility and prices dropped.
Here is the center dash sheetmetal for the '74. My 40 is a '77 and the dash is exactly the same, so I assume this would be an accurate dash for '74 - '77 FJ40's. The '78 changed to have the brake/seatbelt warning lights just to the right of the gauges.
Originally, I was thinking someone would need to cut out their old hacked dash and weld this one in. But after looking at it for a while and looking at my 40, I think it could be a lot easier. The idea was to cut out the replacement right at the start of the radius around the edges and glue it into place. The upper edge will be covered by the dash pad. The lower edge will be mostly covered by the lower pads. The visible edge would be along the crease to the inside of the gauge cluster and glove box opening.
The top right hole is a little wallowed out to an oblong shape. My '77 40 has a blank plug in that hole.
Pics:
Roll Bar Brackets from the '74.
They were carefully cut from the rear tubes. They have surface rust, but should clean up well and look good with some paint. If using on your roll bar, be sure to weld them in as they were from the factory.
'74 Center Dash Sheetmetal is sold pending payment.
Thanks guys
Well, pending deal didn't work out. Dash is still available.
Cover up your hacked dash or cut it out and weld this piece in.
what are the fender signal holes filled in with? bondo or metal? im interested in both of them. PM me with pictures if you have them
How much for Whole tub on the 74? What condition is it in??
The rear tub (door strikers back) on the '74 is already sold.
I would love to cut out any sections of the cowl or firewall that anyone might need. It looks to have a good right inner/outer rocker and a good left inner rocker.
Thanks for all the interest and purchases so far! Lots of good stuff left.
Added: axles, springs, heater blower duct.
77TLCFJ40 said:
The '78 has a cracked block, and no other driveline parts other than the bellhousing. The '74 has even less. Below is a listing of available parts that will be continually updated with price and status. I have access to the trucks most Friday afternoons to pull parts. Let me know what you are looking for and I'll pull them the next possible opportunity. If you don't like the price posted, make an offer. Post here or send me a PM with your email address and I'll send pics. Prices do not include shipping. Thanks
1978 FJ40
Paint layers on most parts: OEM light blue, primer, royal blue, black
Hood SOLD
Right Fender $80 - Signal Holes Filled
Left Fender $50 - Signal Holes Filled, some rust scale and other filler
Aprons $30 ea
Running Boards SOLD
Right Kick Vent with Spring & Pin $15
Front Heater $40 - housing with core
Seat Brackets SOLD
Hood Hinges $30 pair
Door Hinges - Door Side 2 available $10 ea
Door Hinges - Cowl Side SOLD
Doors-Rusty @ bottom but complete $40 ea
Windshield Hinges $45 pair
Dash Sheetmetal with Glovebox SOLD
Windshield Wiper Arms & Blades $35 pair
Wiper Motor & Linkage - Bad Wiring between plug & motor $30
Coolant/Windshield Washer Reservoir Bracket $15
Coolant Reservoir $25
Charcoal Canister & Bracket $40
Windshield Knob Brackets $10 1 left
Hood Release $15
Windshield to Hood Brackets $20 pair
Fan Shroud SOLD
Coil/Igniter Assembly SOLD
Smog Pump Pulley $15
Blower Motor $20
Bumper Gussetts SOLD
Thermostat Housing-Lower $40
Skid Plate $30
Valve Cover $40
Side Cover $40
Distributor - Needs Rebuild $30
Distributor Breather $10
Head & Valvetrain $150
Dip Stick $15
Oil Pan $50
Bellhousing $30
Bellhousing Mounts $25 pair
Motor Mounts $25 pair
Tow Hook SOLD
Air Intake Horn & Bracket SOLD
Dash Pad Light $20
Trouble Light Plug from Glove Box $10
Front Springs - Original - SOLD
Rear Springs - Original - $40
1974 FJ40
Windshield Frame with Glass, Motor, Wipers, & Light Tabs $200
Fenders-Rust thru over support chanels $50 pair Great for tube fender inner skins
Aprons $25 ea
Vent Window Glass - Drivers Side Only $15
Door Hinge - Door Side 1 Available $10
Front Heater Housing $20
Kick Vents $15 ea
Steering Column & Wheel with Ignition switch & KEY SOLD
Bellhousing $30
Gauge Cluster SOLD
Speaker Enclosure $25
Heater Tubes thru firewall-non rear heater $30
Under Dash Light $15
Glove Box Door $25
Windshield Wiper Assembly & Arms SOLD
Fuse Block $30
Wire Harness Parts - Mostly In/Under Dash SOLD
Dash Center Sheetmetal - From the right side of the gauge opening to the left side of the glove box and down to the radio opening/pads $60 See pic
Roll Bar Brackets - $60 See Pics
Heater Blower Duct - $30
Front Drum Brake Axle - Complete with Warn Hubs and 4.11 Diff - $150
Rear Drum Brake Axle - Complete with 4.11 Diff - $125
Front Springs - Original - $50
Looking for 78 aprons. Want to know condition
Thanks
Happen to have two windshield knobs?
Pm sent
