For Sale Parting Out: '78 & '74 FJ40s
Madison, MS
The '78 has a cracked block, and no other driveline parts other than the bellhousing. The '74 has even less. Below is a listing of available parts that will be continually updated with price and status. I have access to the trucks most Friday afternoons to pull parts. Let me know what you are looking for and I'll pull them the next possible opportunity. If you don't like the price posted, make an offer. Post here or send me a PM with your email address and I'll send pics. Prices do not include shipping. Thanks
1978 FJ40
Paint layers on most parts: OEM light blue, primer, royal blue, black
Hood SOLD
Right Fender $80 - Signal Holes Filled
Left Fender $50 - Signal Holes Filled, some rust scale and other filler
Aprons $30 ea
Running Boards SOLD
Right Kick Vent with Spring & Pin $15
Front Heater $40 - housing with core
Seat Brackets SOLD
Hood Hinges $30 pair
Door Hinges - Door Side 2 available $10 ea
Door Hinges - Cowl Side SOLD
Doors-Rusty @ bottom but complete $40 ea
Windshield Hinges $45 pair
Dash Sheetmetal with Glovebox SOLD
Windshield Wiper Arms & Blades $35 pair
Wiper Motor & Linkage - Bad Wiring between plug & motor $30
Coolant/Windshield Washer Reservoir Bracket $15
Coolant Reservoir $25
Charcoal Canister & Bracket $40
Windshield Knob Brackets $10 1 left
Hood Release $15
Windshield to Hood Brackets $20 pair
Fan Shroud SOLD
Coil/Igniter Assembly SOLD
Smog Pump Pulley $15
Blower Motor $20
Bumper Gussetts SOLD
Thermostat Housing-Lower $40
Skid Plate $30
Valve Cover $40
Side Cover $40
Distributor - Needs Rebuild $30
Distributor Breather $10
Head & Valvetrain $150
Dip Stick $15
Oil Pan $50
Bellhousing $30
Bellhousing Mounts $25 pair
Motor Mounts $25 pair
Tow Hook SOLD
Air Intake Horn & Bracket SOLD
Dash Pad Light $20
Trouble Light Plug from Glove Box $10
Front Springs - Original - SOLD
Rear Springs - Original - $40
1974 FJ40
Windshield Frame with Glass, Motor, Wipers, & Light Tabs $200
Fenders-Rust thru over support chanels $50 pair Great for tube fender inner skins
Aprons $25 ea
Vent Window Glass - Drivers Side Only $15
Door Hinge - Door Side 1 Available $10
Front Heater Housing $20
Kick Vents $15 ea
Steering Column & Wheel with Ignition switch & KEY SOLD
Bellhousing $30
Gauge Cluster SOLD
Speaker Enclosure $25
Heater Tubes thru firewall-non rear heater $30
Under Dash Light $15
Glove Box Door $25
Windshield Wiper Assembly & Arms SOLD
Fuse Block $30
Wire Harness Parts - Mostly In/Under Dash SOLD
Dash Center Sheetmetal - From the right side of the gauge opening to the left side of the glove box and down to the radio opening/pads $60 See pic
Roll Bar Brackets - $60 See Pics
Heater Blower Duct - $30
Front Drum Brake Axle - Complete with Warn Hubs and 4.11 Diff - $150
Rear Drum Brake Axle - Complete with 4.11 Diff - $125
Front Springs - Original - $50
PM sent ...
You happen to have the Oil Filter Bracket (mount) type without oil cooler? from the '78?
Thanks
Its still on the truck. I'll pull it this Friday and let you know. Thanks
All PMs returned.
Thanks for all the interest.
Hi there,
Im looking for a front Grill Toyota emblem in good condition (the screws on the back of the emblem are still there)
Also looking for a stock cigarette lighter?
Any good unmolested wiring harnesses?
Right side bottom dash pad next to steering wheel?
Heater core valve cable from dash?
Any help would be appreciated
Joe
Hi there,
Joe
Joe,
Grill emblem is sold
I will be removing the dash sheetmetal tomorrow and will address the cig lighter and all switches and pulls. I already have someone interested in the dash sheetmetal, pulls, switches etc. I'll update later
I am being very careful to remove the entire harness. So far so good. You're first in line for it.
No dash pads
I'll be in touch
Price on the 78 cowl side door hinges (all 4) shipped to 93308. Thanks.
Looks like I only have 1 or 2 cowl side hinges left. I'll let you know.
Today I will be attempting removal of the following:
Radiator Support, Oil Pan, Distributor, Oil Filter Bracket, Side Cover, Valve Cover, Air Rail, Head, Smog Pump & Bracket, Bellhousing, Dash Sheetmetal, Wiring Harness, Pedals, Transmission Cover, etc.
Some of this is spoken for, but most is not.
Say, Lash, you don't have any soft top parts, by chance, do you ?
Just askin'....
Wish I did. Its hard to drive a 40 in the winter even in Mis'sippi.
Joe,
Your PM box is full. PM me with your email address for pics of the parts.
Here's is what I have from your wish list:
Any good unmolested wiring harnesses? Yes - This is the main harness from the passenger's side lower firewall forward to both headlights and up inside the dash to include the fuse panel. The only issues are where the cowl meets the windshield (wiper motor wires) and no fusable link. One of the turn signal connections came loose, but should be an easy fix. Everything else looks great. I have not had a chance to remove or check the condition of the rear harness.
Right side bottom dash pad next to steering wheel? Yes - This is the pad just to the left of the radio opening and was the only pad left on the dash that was not torn! The three rear pins are rusty but servicable.
Thanks
Lash
Dash pics
'74 Gauge Cluster SOLD
Dash Pad Light
PM coming.:)
