im interested in all the seat brackets on the 78 for sure if they are solid, the doors for 40 each if they are the rear doors/ with hinges?
body tub condition?
any front turn signals?
any seats front or rear?
do you have the gastank cover?
how much ?
How much for Whole tub on the 74? What condition is it in??
77TLCFJ40 said:--------------------------------------------------------------------------------
The '78 has a cracked block, and no other driveline parts other than the bellhousing. The '74 has even less. Below is a listing of available parts that will be continually updated with price and status. I have access to the trucks most Friday afternoons to pull parts. Let me know what you are looking for and I'll pull them the next possible opportunity. If you don't like the price posted, make an offer. Post here or send me a PM with your email address and I'll send pics. Prices do not include shipping. Thanks
1978 FJ40
Paint layers on most parts: OEM light blue, primer, royal blue, black
Hood SOLD
Right Fender $80 - Signal Holes Filled
Left Fender $50 - Signal Holes Filled, some rust scale and other filler
Aprons $30 ea
Running Boards SOLD
Right Kick Vent with Spring & Pin $15
Front Heater $40 - housing with core
Seat Brackets SOLD
Hood Hinges $30 pair
Door Hinges - Door Side 2 available $10 ea
Door Hinges - Cowl Side SOLD
Doors-Rusty @ bottom but complete $40 ea
Windshield Hinges $45 pair
Dash Sheetmetal with Glovebox SOLD
Windshield Wiper Arms & Blades $35 pair
Wiper Motor & Linkage - Bad Wiring between plug & motor $30
Coolant/Windshield Washer Reservoir Bracket $15
Coolant Reservoir $25
Charcoal Canister & Bracket $40
Windshield Knob Brackets $10 1 left
Hood Release $15
Windshield to Hood Brackets $20 pair
Fan Shroud SOLD
Coil/Igniter Assembly SOLD
Smog Pump Pulley $15
Blower Motor $20
Bumper Gussetts SOLD
Thermostat Housing-Lower $40
Skid Plate $30
Valve Cover $40
Side Cover $40
Distributor - Needs Rebuild $30
Distributor Breather $10
Head & Valvetrain $150
Dip Stick $15
Oil Pan $50
Bellhousing $30
Bellhousing Mounts $25 pair
Motor Mounts $25 pair
Tow Hook SOLD
Air Intake Horn & Bracket SOLD
Dash Pad Light $20
Trouble Light Plug from Glove Box $10
Front Springs - Original - SOLD
Rear Springs - Original - $40
1974 FJ40
Windshield Frame with Glass, Motor, Wipers, & Light Tabs $200
Fenders-Rust thru over support chanels $50 pair Great for tube fender inner skins
Aprons $25 ea
Vent Window Glass - Drivers Side Only $15
Door Hinge - Door Side 1 Available $10
Front Heater Housing $20
Kick Vents $15 ea
Steering Column & Wheel with Ignition switch & KEY SOLD
Bellhousing $30
Gauge Cluster SOLD
Speaker Enclosure $25
Heater Tubes thru firewall-non rear heater $30
Under Dash Light $15
Glove Box Door $25
Windshield Wiper Assembly & Arms SOLD
Fuse Block $30
Wire Harness Parts - Mostly In/Under Dash SOLD
Dash Center Sheetmetal - From the right side of the gauge opening to the left side of the glove box and down to the radio opening/pads $60 See pic
Roll Bar Brackets - $60 See Pics
Heater Blower Duct - $30
Front Drum Brake Axle - Complete with Warn Hubs and 4.11 Diff - $150
Rear Drum Brake Axle - Complete with 4.11 Diff - $125
Front Springs - Original - $50
