Parting out 1986 Toyota 4x4 pickup truck - Ohio
Ohio
Website
6thgeargarage.com
Update: I am only allowed to edit my first post in this thread, so I can't change the items in the following posts to "sold" or remove them. So I'm going to consolidate EVERYTHING into a new post on - PAGE 2 - (and continue to add/edit parts after that). Please ignore my old posts in this thread as they may be outdated and no longer available. Thanks!
some pics:
Tail lights and front bumper signals are now gone too.
any interest in removing brakes/calipers/rotors/hubs...basicly everything i need to convert my 40 to disks off of the rig and shipping?
I haven't had the front wheels off yet, so I don't know how ugly the brakes are. I'll take some pics when I get them off to see if it's even worth shipping.
DelSol, you need the frt disc brakes off a 79-85 minitruck with solid front axle.
This truck is 86-later IFS, so it's not gonna fly.
6th gear, what size are the tires?
- doors are sold (still have mirrors and interior panels)
- rear section of the harness is sold (from the cab back)
- face from climate control sold
everything you see left in the engine bay is avail.
Charging harness and fuse box SOLD
left to right: coil plug $5
Neg battery cable $5
22r engine harness $10
Main harness $75
All seat belts SOLD
Driver's side mirror & hardware $20 (keeping right one)
Brown kick panels $8 ea
Brown A pillar both SOLD
Door sills $8 ea.
Brown rubber trim pieces:
Around door opening on cab $5 one left
Front of headliner $5
Main dash structure $25
Brown Dash Pad, tiny crack on backside (in front of finger nail in pic) $100
Brown & Black Cluster Surround w/ clutch safety override switch & vent $20
left to right:
Ash tray and metal casing $10
Black DIN storage under radio - NA
Brown Coin holder $5
Glove Box and white plastic + Black metal piece $25
left to right and top to bottom:
Steering column trim top and bottom SOLD
Radio/ashtray cig surround trim $10
Rear view mirror/dome light $20
relay $ 10
ecm $20
hood release $5
Climate control, knobs (face already sold) $15
right speaker cover, bent tab $10
Gauge Cluster 108k mi. $40
Owner's Manual $10
UPDATE-
the following has been sold:
both doors (still have interior door panels)
rear harness
climate control face cover
shift boots
alternator
engine harness/fuse box
Lower drivers dash piece, dimmer knob $20
visors & clips $25 for all
Cab trim pieces from behind door $15 ea.
Oh ˟˟˟˟ handle $8
Inside door handles $8 ea.
starter relay $15
shift boot - sold
rusty horn $5
Exterior Cowl cover, white just really dirty, $35
Windshield defroster vent $5
Throttle cable (or is that hood release?) $10 and I have both
Antenna - pending
Interior door panels $15 ea
handle surrounds $8 ea.
Window cranks $8 ea.
22r intake & resonator box $5 ea.
Washer fluid tank w/ pump $20
coolant overflow tank $10
Starter $35
Coil/ignitor $75
Shift knob (prev owner must have worn rings on right hand) $10
transfer case knob - good cond. $15
Rear Driveshaft $75
Driveshaft Bolts $5 for set of 4 (4 sets total)
5 speed clutch/brake pedal set, hardware $20
Brake booster $15
Hood latch rusty but works $5
OEM mud flaps
Front pair $25
Rear pair w/ brackets $40
5 sp Transmission 108k mi $250
Transfer case 108k mi $200
Front driveshaft $45
transfer shifter $10
transmission gear shifter $15
Speedo cable $20
22R bellhousing $40
Plastic front inner fender pieces $ 10 ea side
Inner fender Rubber flaps that cover gap between body & frame $5 each side
I need the metal part of the gas fill, the part that bolts to the bed under the little door, holds the cap. Mine is really rusty. Any chance?
Sent from my DROIDX using IH8MUD
I've got it but it's rusty.
Seatbelts? Think they fit a fj60?
seatbelts have been sold
I'm updating the thread with a ton of pics above :D
OEM fusty fenders, good for trimming for big tires on a trail rig, not much else. $10 ea
Hood, rusty underside $35
Rubber gas door to tank neck filler what's this thing called? $5
updated w/ more:
Front Diff $100
gas tank $50
Steering stuff:
Pump $40
IFS steering box $100
Shaft $15
Steering wheel $25
Column $25
ignition w/ key $15
turn signal lever $20
I didn't get the hubs off yet, it will probably be another week or 2 since I still need to be able to push the chassis around.
I started pulling the steering parts... got stuck at the ball joint and called it a night. I'll get it off this week.
For the box, pump and res = $165 shipped.
