For Sale Parting 95 FZJ80 SoCal
The messed up part is whomever broke in took a sh*t in my toilet too... That's just messed up
That is fawked up. The perpetrator left his DNA behind, but since it wasn't murder, the authorities won't spend the money to retrieve it.
Hope it works out Pat! Let me know when I can stop by and check out the parts cruiser.
Derrick
jbpace- It does have power seats, so I guess yes. I'll have to get them out and see. I'll get back to you.
If the seats are still there you probably have the parts I need.
My trucks PO solved the frozen seat problem by removing one adjustment rod from each seat:
I need the missing components from the DS outline that appear in the PS outline [threaded rod, the nut on top, the 2 bolts & mid-support bracket and the 2 screws on bottom].
PM me if that's available.
Thanks,
Jon
I need the hood if its still available ans straight. Im in SD so can come get it whenever. I will PM as well.
Do you still have the rear driveshaft (both pieces) and the hazard light switch? If so, what shape is the driveshaft and ujoints in? And how much to ship it to TX 76210?
Any chance you have the connector from wiring harness to the neutral switch relay? Mine burnt out and I replaced the neutral relay switch but am trying to find a good male connector in lieu of buying an entirely new wiring harness. I can send you a photo of neutral switch if that helps. Neutral relay is part # 84540-30270
Need passenger side running board and ALL associated brackets, hardware, etc. I also need a good passenger mirror assy. that does not 'shake'. I'm also looking for the "LAND CRUISER" emblem just below the glass on the rear hatch. I can pick up depending on where you are.
PM'd you too.
Looking for the two front sway bar brakets for an fzj80.
these are the ones shown on the lower right corner of the two photos shown below..
How much shipped to 91722
Thanks
PM sent for Rear Lower Control Arms, front bumper end.
Cylynder Head
Hi,
I'm looking for a whole cylinder head with cams, lifters, springs, everything. do you have it?
Thank you
Hey Landcruiserman,
on your picture#1 the center console beside tha hand brake (only the top middle and the cushion) If still available and how much ship to toronto.
thanks,
joon
Lid for the center console?
