So here's the deal. 94 fzj80 thinks it's in drive and park the same time. The result is it will only give me 2nd, 3rd, and 4th gears. No first gear and the torque converter won't lock up in 4th to give me highways speeds at a reasonable rpm. I can select 1st manually, but it won't do it on it's own. The gear selector lights in the cluster tell me that the truck is in drive and park at the same time when I've selected either drive or park. If I select reverse, neutral, 2nd or low the selector lights act normal.
So far my guesses are the neutral/park switch or a bad ground somewhere. Has anyone had this happen or have any thoughts?
Thanks
Thanks
