I used a few studs to line it all up. That and a gallon of RTV. You are fast becoming the F, 2F, 3FE oil pan/gasket expert.
Just as a side note there are now two pans for a 2F and the gaskets aren't compatible. If you buy a new pan (which will have a smaller drain plug then the original) you need a new matching gasket. I was replacing my gasket, got the pan off and decided to just replace it rather than try to patch the pin holes. The gasket that I originally bought didn't fit the new pan. It looks like the corners of the new pan near the saddles are different (perhaps to reduce the common leakage spot?).
