I found this great thread which has most of my info. I am replacing my evap, drier and condenser with Denso units. Compressor was replaced by PO so i will give it a go. I also replaced all o rings, schrader valves in compressor and big square o ring on the compressor. I removed my compressor and drained all the oil. replaced the parts and filled it with 150cc oil. I figure there is probably about 25cc old oil in my lines and a little left in the compressor. So i should be close to the 225cc factory volume. But i can always add 20cc or so to my drier or whatever.
What do you guys think? Run it as is or add some as i install the new parts?
I just did my wifes Honda system and it shipped with 100% of the oil in the new compressor. So i think that is the standard way to do it. But i also know if you replace just one part you can add some to that one part as well.
