P0172/PO175/P0101 and secondary air system bypass
I’m getting these codes on my 2007 LC. Tried cleaning MAF, replacing MAF with aftermarket, and the codes are still coming back. Inspected all the intake for cracks and all looks good.
The codes started as once a month, then went to once a week, now they are everyday.
I put a plug and play SAI bypass kit on the LC preemptively more than 10 years ago after dealing with the SAI codes on my wife’s GX.
Could my SAI bypass kit be causing this? Is there a newer better kit that’s recommended? Thanks in advance
@2001LC is the "Messiah" of this issue. He has an amazing thread that if I owned an SAI Cruiser, I would follow too the tee. Good luck!
Remove the SAI block-OFF junk. If was type, wired into MAF; Replace MAF also!
Thanks guys. Down the rabbit hole I go!
Might there be a cliff notes version for those of us with ADD?
Run it through AI like Grok or ChatGPT to summarize the main points
