Anyone had the CEL (P0171, lean in bank 1) only pop on right after getting on the highway up to speed? It then stays lit until I disconnect battery for ~5 minutes, goes away, then goes around town and up big hills fine for several days, then pops right back on after I go from low speed and get it up to speed on a highway on-ramp.
Anyone had that particular failure mode and which part fixed it?
176k miles on LC. I went ahead and swapped air filter and fuel filter (needed done), sealed one possible vacuum leak. Did a quick spray with electronic cleaner on the MAF, but may try harder with that. Got a new PCV to pop in in the next few days. Wondering if a long vacuum drag on that PCV overcomes a weakened spring/ball or whatever is inside it which develops in to lean condition only on those on-ramps.
If that doesn't solve it, I'm getting to more expensive parts to try (MAF, O2 sensor, etc.), buy a fuel pressure guage, etc. If someone else had that same on-ramp failure mode for say the MAF or 02 to help narrow it down, that'd help me out.
I certainly have exhaust leaks downstream near the middle muffler, but those have been there a while, and are way downstream from O2 sensor. No obvious leak near manifold, only ticking I can hear is probably cold valves. I've also done a can of seafoam in tank several months ago.
Thanks for help.
edit: Solved, I think. Smoking gun found. Bank 2, Sensor 1 oxygen sensor was loose in threads. Apparently codes can lie as well, as fuel trims indicated lean issue on Bank 2, despite P0171 saying issue on Bank 1.
Thanks for help.
