p/s pump number
Gumby
Supamod
s-Moderator
Knee deep in hookers and gin
For the archives -
To add extra volume for ram assist or cooling or hydro-boost
GM power steering pump for use with external reservoir -
GM number 6003042
Carquest number - 20-7923 - Application - 87 G series van with 6.2L and hydroboost
The external reservoir is not included or available from CarQuest.
You also might check out the Astro vans. Some of them got hydro boost. I got the Astro pump and reservoir at a pic-n-pull and it looks the same. Just need to compare part numbers to see if they are indeed the same. I've also wondered if the complete Astro hydro set up would be worth trying.
Great tech!
When I changed to external resevoir to support hydro-assist, I cut the top off the reservoir of a regular sag pump, capped it and welded a fitting on. It has always worked, and the extra resevoir on the pump is nice, but I was never sure what I would would replace it with were the pump to go south. Now I know!
